Hello Community,
I'm hit by an electrical problem and I have now clue what is.
What happened: After a 3 hour ride at speeds of 80-100 mph (I'm from Germany you must know), all of a sudden the 30A main fuse blew. I was on the left lane overtaking and suddenly all electrics except the HISS lamp went off. Just like somebody had the ignition switch turned to off while riding. Just managed to pull to the hard shoulder. Checked and found the 30A fuse next to the starter relay blown. Put the spare fuse in, let it run for 10 Minutes on idle with the hand on the relay/fuse to check the heat. All ok. Bolted everything back together, put my stuff on, 1st gear revving up und after a few meter the same happened again.
Finally I was recovered by the ADAC (AAA equivalent) and my bike was returned home a week later. Back home I checked the fuse, it was blown of course and put a new one in and since then the beast runs without any problem. So I checked all the wires for signs of shorts, all relais and connectors as far as I could reach them. Opened the switches to check for corrosion, nothing.
Without having a concrete finding, I changed the fuse/relais unit and the battery (it was a no name gel battery before, that although only 2 years old it seemed a bit tired) as a preventative measure. The first 200 mile trip was ok, but a bad feeling remains.
Does anybody have similar experience with such self-healing phenomenon?
Kind regards
Klaus
Kind regards
Klaus
