40 amp Alternator removal st1100
uk london
Hi my 40 amp alternator case is cracked I need to Repair it is it possible to take it out without removing the swingarm ?
kiltman
Stratford, Ontario Canada
2002,ST1100ABS
8826
No. You will need to remove the swing arm. Once that is done it takes about 15 minutes to swap the old for new. A new rubber boot would be a good idea . You will need a special tool to remove the swing arm nut and to reinstall it to the proper torque specs. That tool is easy to acquire in the UK off of eBay
uk london
Thanks for Quick reply
