Well my bike hasn't hit three years old yet, but pretty close, and I just did the 80K valve check yesterday. All were within specification so no adjustments necessary this time around.
I put all my prior valve check information into a spreadsheet to get a better overall look at how they have done. One of the things I noticed is that overall they have been fairly stable. You may ask, "what is stable?" so I'll clarify. For all 16 valves the average variance has been 0.00056" in over 80K miles. I have only adjusted 2 valves in 80K miles, one exhaust that needed it as it was under spec and one intake that was on the low side and I already had that side apart. There were 6 valves with literally zero change, 5 with -0.001", 3 with -0.002" and 2 with +0.001". Since a picture is worth a 1,000 words I've attached a screen shot of the numbers.
I can't really explain why some of the numbers are what they are but I've got an idea or two. A couple are, new shim not fully seated because of fresh oil applied to shim before putting it in. Cam position off a few degrees difference between measurements. Wear besides at the valve seat. All I can say is these are the numbers I came up with, and I do the checks twice to help avoid errors.
