number9
Tom, it sounds like you need to tear the bike back down, drain the coolant a bit so you can remove the T-stat housing and be SURE the T-stat is seated and sealed properly and also clean the knecks off good with a wire brush to get them to seal the best they can.
You may need to use some heat (heat gun) and lube (vasoline) on the hoses to get them on the T-stat housing. I had a time with mine getting them fully seated.
This is not a job you can rush or do less than 100%. You certainly don't want a coolant system failure (leak) in the middle of the desert somewhere in June because of trying to cut a few corners.
