Working on a 93 ST. This is new to me. Not charging. Checking with OHM meter. Black to white 2.8 ohm, open to ground. When Key on I have battery power to the black wire. 3 yellow wires Red connector, .6 ohm all combination of them, and 2.3 ohm to the case. Engine running about 2K RPM, Red connector, yellow wires. 37 AC Volts out of the 2 parallel terminals. One of the parallel to the 90 degree terminal 37 AC volts the other terminal to the 90 degree is 14 volts. Not sure if that lower voltage is correct?? Even if it not correct I think I should have some higher output voltage to the battery. Just battery voltage at the battery when running. I think the the rectifier Regulator is bad. I have searched google and ebay for the upgrade 40 amp for the 91-95 ST not any luck finding anything. The 96 and up there is lots of them out there. So what do I need for the 93 ST?? Stator, Rotor (armature) and mounting plate?? Does somebody have all the parts?? Post a link.. Has anybody used another 3 wire rectifier, then ignition hot to the black wire. There is other Honda rectifier / regulator out there for $20. instead of over $200. they want for this one. Also the previous owner must have changed the stator with a new Honda one. I have another used stator. The cycle has set for some time because it did not charge. Is there any files on how to do the job?? youtube does not have any complete videos on the early ST but some on the 96 and up.. The picture is of the 2 stators I have. Thanks for the help!!
