- Joined
- Mar 18, 2006
- Messages
- 2,832
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
I use the term 'stranded' in the loosest possible sense. We have come to Snowdonia for the week. Yesterday the bike was parked in the car park. I could sit and drink coffee, see the bike down below, and wait for the arrival of the RAC guy while drinking in the ever changing scenery of sunlight, mountains and cloud. There can't be many views better than the view north to Snowdonia. Occasionally the top of the mountain emerges from the blanket of cloud that covers it most of the time.
So, no, stranded is not quite the correct term. I was just unable to ride the bike. The battery was dead. Flat as a pancake.
2 days before, we had ridden into Wales from Derbyshire, and it will be no surprise that Wales offered us its customary greeting of a series of deluges. That's ok, the gear is up to it. Most of the mountain roads have oodles of grip and it was starting to dry as we got to close to our destination for the week.
The following day (Saturday) was battering down with rain. We didn't go anywhere, and the bike looked pristine having gone through hours on the rinse cycle with very strong winds.
Sunday was also wet, but we took the bike out for a short spin to see a couple of local places. It started first time, as always.
Monday was glorious. We planned a trip around Snowdonia and further south, got all togged up, got on the bike, turned on the ignition. Dead.
I know you can bump start these bikes, but you need a fair amount of power to be generated - in the Uk , headlights are always on and are a significant drain. It can be hit and miss, at the end of which the bike is now in the same state as before, but at the bottom of a very steep hill.
So we wait for the RAC. He checks the battery and it is reading 5 volts. He checks the flow of current back into the -ve post. Hardly anything.
He puts the jump start unit on the battery and it fires up first time, and then he monitors the flow of current into the battery which is steadily increasing. So we leave it running for 15 mins at 2000rpm, and then stop it, wait a few minutes and it fires up first time on its own battery.
So we go for a ride for a few hours, stopping once for about an hour. It starts ok when we return. It is left overnight, and this morning I tried to start it, and again, it fired up first time.
Now, I do have accessories wired in. There is one 30A cable attached to the battery via an easily accessible two way connector, and this feeds in to two relays. One relay is triggered when either ignition or accessories is on, the other is only triggered when accessories is on. So in theory, nothing can be live when the ignition key is removed.
Except one thing. I have Innov K3 cameras installed. These draw a small amount of current all of the time so that they can start up and close down the files correctly when the ignition is turned off. I have a connector under my seat which is easily unplugged to isolate it completely, but I had left this connected in the garage at home for 3 weeks - during which time the bike was not ridden - just to test how much drain it actually put on the battery if it was left connected. There was no significant drain on the battery, the optimate had it down by just 1 bar, and the engine fired up without any hesitation. So since then I haven't bothered to unplug the camera.
But last night, having got it back to where we are staying, all if my add ins were unplugged and it started first time this morning.
The only things that I can think of are :
That the camera power unit had failed, so it was drawing a full amp every hour;
A power relay for my accessories had failed to switch off when ignition was turned off;
That water ingress into an always live connector was seeping power away to earth.
I'll be investigating all of them when we get home, but for now, every morning will be a pleasant surprise if the bike fires up. And on Friday when we go home, we might well be in the back of a pickup truck.
Any other idea would be most welcome.
