I took a day off from riding to address some overdue maintenance tasks. In addition to oil and coolant changes, I performed the valve clearance check. I've got decent mechanical skills, but was still nervous with the extent that one has to dig into the engine to check the tolerances.
I can report that all parts disassembled and reassembled well. I did not have shims on hand to make adjustments, if needed, so I was hopeful that all would be in tolerance..... this is where I need some advise...
I took my measurements with a common angled leaf style set of feeler gauges. This presented my quandry - I have three exhaust and one intake that are questionable. What do you think based on the measurements?
Exhaust #4 left, #2 left and right [spec 0.25 +/- 0.03mm]
The 0.279mm gauge passes between bucket and lobe, but the 0.305mm will not pass. I have no other gauges to try between the 0.279mm and 0.305mm.
Intake #2 left [spec 0.16mm +/- 0.03mm]
The 0.178 gauge passes, but the 0.203mm will not. I have no other gauges to try between the 0.178mm and 0.203mm.
Unfortunately, the gap between these gauges does not tell me if the clearances are in spec or out. What are the potential consequences of these tolerances being too large?
I believe I will investigate getting my hands on the HOT CAMS shim kit that is being passed around and reset these back to nominal when convenient. Any reason for concern at this point?
