. . . . and then there were none !
STill STylin
Red is ALWAYS faSTer
Pasadena, CA
2005 ST1300A
1038
With evening temperatures gentle and delightful planned for an evening ride with like minded friends.
Bike STarted right up - and then noticed something that was not very good for an evening ride.
Both, both headlights were out - completely dark, and had been fully functional yesterday.
Checked the obvious: headlight switch and fuses, and electrical connections running to the headlights. All seems in place as it should be.
STumped - could problem be a relay?? or??
Ideas?? Assistance, Help?? Guidance??
Please.
Thank you,
-Elliot
v8-7
Bradenton, Fl
I had the same problem. i was able to wiggle the hi-low beam switch side to side and they came back on.
STripper
Brian
Redmond, WA
2005 ST1300A
  • Fuses D and/or G
  • The Hi/Lo beam switch, as v8-7 suggests
  • The starter switch
Good luck!
Nashcat
Theta TN
2015 Versys 1000LT
8591
My vote is a stuck starter switch. It happened to me. Wiggled the switch and the lights came on.
STill STylin
STill STylin
Pasadena, CA
2005 ST1300A
1038
WOW !!!! Incredible !!!!
Got a dental issue - recommended behavior - see a dentiST
Got an ST issue - recommended behavior - poST it on ST-Owner's.com
Jiggling the STarter switch assembly (if that's what its called) and doing so was inSTant remedy for me - wow, don't know if I was more pleased than surprised or vice-versa ??
Removed the screw holding that unit together - was then able to "jiggle" the entire assembly. That did it - inSTantly - both headlights lit upon STarting the engine.
I'm so grateful - getting STarted a bit late for the ride - but surely will catch up with those sissies in no time flat. Couldn't wait to poST this good fortune.
Thank you !!!!
-Elliot
STill STylin
STill STylin
Pasadena, CA
2005 ST1300A
1038
Glad you found the simple fix. After you get back, I'd go through all of your switches and apply a good contact cleaner.
Also check the connections etc.
A very good idea, indeed.
Can you recommend a good "contact cleaner" ?
Thank you,
-Elliot
