Here is :tc1: more for ya to think about... Notice that st11ray & racer1735 both mentioned a fuse block. Having just bought, but not picked up (AAArrrgh!), my first ST, I can't speak to the particulars of mounting an outlet. However, having created more than one rat's nest of wires coming off of a motorcycle battery, I have already ordered an auxiliary fuse block. Sadly, you missed the group buy by a few days, but here is the link to the one I'm getting:
http://www.cyclenutz.com/products/e...e_panel_relays/fuzeblock_fuse_block_fz-1.html
Here is a link to an MOA (BMW Motorcycle owners of America) article:
http://www.cyclenutz.com/documents/reviews/fuzeblock_MOA_article.pdf
On my Ninja I made a distribution block (quite simple), but here is why I ordered the "fuzeblock" fuse block:
1: It is designed such that you can very easily change an entire accessory circuit (say, heated gloves or gear) from "on only when the key is on" to "on all the time," by simply moving a fuse. I will go to whatever trouble it takes to mount the fuzeblock in an easily accessible place.
2: At any time in the future adding a fused accessory circuit will be a piece of cake (and all should be properly fused!!) (Have you ever seen a guy try to extinguish a fire on a motorcycle? It isn't a pretty sight!!)
3: It appears to be a well thought out and quality piece of work (Will post again when I get it.)
Good luck!!
Rod
