Anyone de-linked the brakes?
Hello...you've reached Igofar's white courtesy phone...if you'd like to leave a message or a call back number, please push PM, leave your message, then click send....
Your calls will be returned in the order they are revieved...have a great day, and thank you for calling the white courtesy phone.
Thanks Joe...Here I have 154K on my '05 and the brakes just seem to keep working ....All I have ever done is to bleed them a few times and and clean the pistons when replacing the pads. :eek::
Maybe because I'm riding it all the time, it keeps things moving....:think1:
Although, I'm sure if Larry (Igofar) looked at them, he would say they are in terrible shape...lol
You do realize that it is possible to just ride it into the ground right? :rofl1:
Just a reminder to all the folks following the SMC/Brake Dragging issues...
There is another master cylinder that is often forgot near the foot lever.
I wonder how many people inspect and clean this one during their services?
HolliSTer, CA
2012 ST1300A
What does Honda say? If you trust that dealer's technician- why not book it for a first thing AM visit and go enjoy the day in that town (or drop it off and fetch it another day)? Brakes are kinda important, so I'd not settle for "fixed"- culprit identified and exorcised!
New Jersey
st1300 '04
7163
Which would kinda point you there instead of the smc if the rear locked up with the pedal while NOT under motion.
Rochester, NY
2008 ST1300
8441
I've thought about de-linking a few times, mainly to prevent the rear lockups I've read so much about on here, but also because the rear pads wear out too fast if you brake with the front assist and rear pedal.
What would happen in Jacks case if he simply unpinned the smc joint from the holder such that applying front brakes did not activate it? The rear pedal linking would still function up to the front (more important IMO), but the front would no longer link to the rear?
Of course, this would only fix the problem if your rear brakes work normally off the pedal and only locked when braking front while moving.
Santa Clara, Ca
2007 ST1300
8525
154K? I would buy a new rear master cylinder. The fact that the front brake doesn't cause the rear to lock rules out the linking. I would just order a new rear master cylinder and call it done. Sounds like the bleed off circuit on the rear master cylinder is plugged.
My original post didn't have enough information, I guess........here's kind of a flesh-out!
My rear brake seized today on my Honda ST1300; and I had to crack open a bleed nipple to get the pads off the disc.... I nursed it home then, and had seemingly normal front brakes. Safe at home, I'd pump the front lever and everything was okay, the rear caliper would not stick, but if I so much as touched the rear pedal, the rear caliper would clamp tight, and I'd have to crack the bleed nipple again, and pry the pads away from the disc...... and when I would crack the nipple, the brake fluid pulsed out like an arterial wound!
Two years and 17,000 miles ago, I put on a brand new secondary master cylinder, built myself a home-made vacuum bleeder (see pic), bought a shop manual, found an illustrated guide (on here, I think) and bled the brakes as carefully and as well as my wife and I could. I live in a small town, and the dealer is a mountain range and 115 miles away, and so we do our own work. And everything was fine with the brakes, until today.....the rear disc would sometimes feel warm during the "okay" time, but never overly so. If anything ever causes me to sell the ST, it will be this issue. I'd still like to delink the brakes somehow, with plugs and custom lines, and go back to front lever/front, and rear pedal/rear. Damn engineers are too clever for their own good.......
How should I start with this problem? Clean and maybe rebuild the rear m/c? Redo the whole system again, with a new SMC (my second in 36K miles)? I don't mean to be a crybaby; I love this bike, except for this issue....
If you removed the SMC by altering the plunger (unpinned) you would also be removing the use of most of your rear brakes. Refer to diagram in service manual.
Anyone out there open up the REAR master cylinder by the foot lever to inspect it before?
Justytroll may be on to something here.
Mississippi
2007 ST1300
Great point. although SMC is the root cause very often, a complete disassembly and cleaning of the ENTIRE brake system is the only way to verify.
Just a thought, Like Igofar suggested, you can have more than one faulty component during a failure process.
Waaazup doc?
Williamsport, PA
4138
Service Manual page 17-6 Troubleshooting~Brake drags == Contaminated brake pad/disc, Misaligned wheel, Clogged/restricted brake hose joint, Warped/deformed brake disc, Caliper not sliding properly, Clogged/restricted brake hydraulic system, Sticking/worn caliper piston, Clogged master cylinder port.
Rear wheel locks when only the brake lever is applied/Front wheel locks when only the brake pedal is applied(in the case that all items are normal in "Poor lever/pedal brake performance." = Faulty brake porportional control valve.
I would be looking at the rear master cylinder having the bleed hole being blocked and if that was okay I would suspect the porportional control valve. If prior experience points to the SMC, then go for that instead.
Rochester, NY
2008 ST1300
8441
I see that the SMC pushes on the two outer pistons, while the pedal only actuates the center piston. Too bad this isn't the other way around!
Uncle Lumpy
Doc Holiday
Ohio
<snip>
Cousin Jack, I've been contemplating de-linking my brakes as well. I've come to the conclusion that it would be easy to do, but maybe somewhat expensive. I would put in custom length Spiegler braided brake lines. I used Spiegler items on my SV1000 6 or so years ago and was very happy with their service. I would run a dual banjo bolt from the front MC. Each braided line from the front MC would split and be routed to the 4 front caliper banjo bolts. The dual banjo bolt from the rear MC would send two lines to the rear caliper, one for each rear caliper banjo.
Because the front MC would now be pushing 6 caliper pistons rather than the 4 it currently pushes, I'd be concerned about whether it would push enough brake fluid. Given that, I'd probably buy a 2006 Honda CBR600F4i front MC and install that instead of the ST front MC. The 600F4i's front MC normally moves 8 pistons, so it would certainly move enough brake fluid to move the ST's 6 front caliper pistons.
I would drain whatever fluid was in the SMC and then use non-banjo bolts to seal the openings and just let the SMC hang there rather than trying to mess with the ST left front caliper.
I would also pull off all the original brake hoses, brake pipe, proportioning valve, and delay valve stuff to keep the brake system as basic as possible.
This might end up being my winter project if I elect to go through with it.
Uncle Lumpy :06biker:
Cousin Jack
Ellensburg, Wa
Wowser! I just got off the phone with Igofar....... what a guy! He's already taught me more about the ST's brakes than I realized that I had to know! Just as valuable, he's given me enough confidence to believe we can beat this thing! What a valuable resource! What a great forum!
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Nah, if it needs replacing, it will be replaced, but brakes and carbs were never my strong point! I do get by with them tho and the brakes seem to stop when I need them, so I must be doing a few thing right...lol
Just glad I don't have to deal with carbs any longer. :D
From what I hear, you do quite a few things right ;)
As far as Carb Vs. EFI...I'd rather have a good old fashion carb any day.
Call me old school.
Thank you for the kind words :eek::
Let me know when the TOOL arrives!
