Nope.. Miracool for me; reloaded as necessary..Veskimo for you. Cumbersome, but IF it's the difference between ride and no ride, easy choice.
John-
John-
+1 on using it under a relatively closed jacket. I have used it with a mesh jacket as well, but I found that it dried out much, much faster - especially in low humidity. When I wore it under my aerostich jacket, with all of the vents open, it provided plenty of cooling and remained wet and cool for a couple of hours vs. about 45 minutes under the mesh jacket.When I do, I actually keep my Stich pretty closed up to extend the cooling effects.
Looks like Tuffrino has them on sale w/free shipping right now. The one thing that they do not show is how many packs does the vest hold and how are they set in the vest?This is where I got my P change vest... Amazon..
http://www.amazon.com/Cool-U-Phase-Change-Cooling-Vest/dp/B0002EWKUC/ref=sr_1_1?ie=UTF8&m=ASVP5ZC56BDXR&s=sporting-goods&qid=1247783086&sr=1-1
Same thing but less expensive..
http://www.tuffrhino.com/Standard_Vest_p/hs3023.htm
Extra packs...
http://www.amazon.com/Inserts-Phase-Change-Cooling-Vest/dp/B0002GTSIM/ref=pd_sbs_a_5
mitch
Just got this in an email ... sale of Phase Change jacket - Looks good but does this sort of thing really keep you cool or warm in extreme weather??
Use coupon code SMART during checkout for $30 off
Well that `splains it. ThxIt does use the buzz-word "phase change", but is very different from the jackets discussed in this thread.
The jacket you see in the ad changes pore size, to let more or less air through depending on your body heat.
The phase change cooling jackets mentioned in this thread holds approximately 5 lbs worth of removable packs filled with an oily substance that "thaws" over time, providing constant active cooling, like ice would but at more comfortable temperatures.
I have a mini cooler (walmart ..whatever) which I stage with ice, drinks and my cool vest. When the temp hits 95 or higher I put on the vest it is heaven....for about two hours. I wear it under a Stich with a T.When Byron and I were riding out to Taos for WeSTOC 2008, when we stopped for gas, I would buy a bag of ice and a half of gallon of water and soak our cooling liners in a plastic bag. It kept us nice and cool, and we were in temps from 101 to 113F much of the way!
