- Joined
- Mar 18, 2006
- Messages
- 2,832
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Removed
Yes to both, just handy to have, don't always need them.Are the blocks needed to press against the tread to shove the bead on one side into the centre depression - to gain a bit of extra 'slack' on the bead on the other side where the lever is to be inserted ? Or do you use them to press the beed away from the rim so that the lever can pull the slack across by itself ?
Presumably, once started when removing, the rest is quite straight forward.
Do these things need to be bolted to the floor ?
Not to knock anybody for balancing the old fashioned way, it has definitely been proven to work, time and time again.I got a simple Pit Posse balancer, and it works a treat!
Some one did exactly what you suggested - drilled new holes. My problem with that is then you are locked in to specific wheels.Many thanks for all of the input, folks.
The two pinned holders - - how did you sort that out ? Presumably you could drill holes for the retaining peg vertically in precisely the correct location for the wheel. I wonder how they expected it to work ?
The mandrel itself - presumably this has to fit through the wheel bearing ? so 20mm or 25mm for rear and front respectively. The one I linked to says it has 12, 16, 19, 24 mm diameter posts - so I assume 1mm play is OK ?
Or maybe we have not learned to spell.Aha - thanks for the info on that - I found the link eventually. I did look for the info before I posted this thread - which Joe had to move to the correct forum.
Some of us on the UK/USA* side of the Pond seem to spell the word Tyre/Tire* incorrectly/correctly* which result in 0/000's* of results when searched on a USA based forum. (*delete as appropriate). All of which is my excuse for not finding the correct forum and articles when I first looked.
Just for completeness (now I have learned how to spell)
SMSW's review of the HF changer is here: https://www.st-owners.com/forums/showthread.php?160721-Harbor-Freight-Tire-Changer-A-Review
And GregJ's contribution is here: www.st-owners.com/forums/showthread.php?29957-My-no-mar-tire-changer-(HF-Mods)
I do fancy the idea of being able to switch out my own tyres, but I'm beginning to wonder if it might be cheaper to buy a new set of wheels and have one set all ready with fresh rubber for when I want to change them !
Or not cleaning the old gloop off thoroughly before applying new? Buildup of any kind can defeat the seal. But your gloop/no gloop of choice can bring peace of mind.jfheath said:due, apparently, to using tyre sealant gloopy compound.
