So i just got my ST1300 and I am currently (yes already) installing the audiovox cruise control on the bike using "ray's" instructions. i have everything mounted and wired everything. I took it for a test ride and it DID NOT work, so now i'm trying to post for ideas on what might be wrong.
i used the led light test method (in the audiovox instructions) to be sure the switch and brake light sensors were working. but other than that i don't know what could be wrong. HELP.
in the Audiovox instructions it states that if it installed without a VSS/Magnetic pickup then you should remove the black jumper on the servo unit. i tried both ways and it hasn't worked.
is there a minimum speed i need to be moving? (how could it tell with no speed sensor)
i am using the vacuum canister (homemade with ABS Pipe)
i dont want to put the bike back together without the cruise working...
