Ncphoto1
Jay
avg displayed is 41 mpg.
How do you switch from instant mileage to average mileage?Thanks for the info. This forum is pretty amazing as a new st1300 owner. I rode in this morning. 43 degrees and I slowed my speed down to 70-75mph. I switched to the instant mpg instead of the average, and I was getting 43-45 mpg.
Unless I’m missing something, based on the responses I’m getting this is about right. It’s damn cold in the early morning, and although I dont necessarily goose the throttle I ride at higher freeway speeds.
Your speed is a huge influencer on MPG. If you coast around smaller roads on a nice summer day (55 mph) you will likely see close to 50 MPG. If you jump on the freeway and go 85 mph you will be in the upper 30's MPG. That's just physics...Its pretty cold and wet here in Seattle. I leave for work early in the morning and the ambient air temps are in the low 40's. I also ride at about 75-80 MPH most of the way, stock windshield all the way down, stock muffler also. I checked the rear tire for brake drag and it looks to be spinning freely with little/no drag. My next check will be the air filter. Will my speed affect MPG THAT much?
This is the very best internet forum I have had the pleasure to be a part of. Many former ST owners still check in here even after moving on to other motorcycles. A tremendous resource.I’m a new owner. I’m learning a TON from this website and it’s a little addicting. The buttons on the left next to the headlight angle adjuster will allow you to toggle from blank-realtime-average mpgs.
I bought this bike a couple weeks ago and I’m trying to be a responsible owner and care for the bike the best I can. It’s a commuter for me and I spend most of my time on the freeway. I’ve been cruising along at about 80 mph , but today slowed down a bit. Im going to use the real-time mpg setting for a while and see what I am getting.
the knowledge base here on this forum is really good.
Yup. Motorcycles are as aerodynamic as barn doors. Back in the good old days, we had a 55 mph national speed limit. I remember the graphs that showed how gas mileage dropped as the speed increased from 55 mph to 60 mph. As the speed increased to 70 mpg, the curve rose dramatically. The increase in fuel used is not linear. It's more like an exponential curve....I also ride at about 75-80 MPH most of the way, stock windshield all the way down, stock muffler also.
...Will my speed affect MPG THAT much?
If the speedometer is accurate it has some kind of correction, which means that the odometer is off, or it is a very rare ST1300. The difference will affect your fuel consumption readings as compared to the calculated numbers.The new one does have a spot on speedo, and is quite farkled by the PO, so perhaps a speedo healer is throwing off the odo. I will have to check it against milepost markers.
I'm assuming it has a corrected speedo. I wonder, if the odometer is under recording by 10%, would I be getting another 10% better mpg than I'm hand calculating? That would put me upper 40s US mpg, which seems pretty high.If the speedometer is accurate it has some kind of correction, which means that the odometer is off, or it is a very rare ST1300. The difference will affect your fuel consumption readings as compared to the calculated numbers.
I have tracked every tank of fuel that I have burned in my ST1300 since new. The average fuel consumption reading displayed on the fuel computer has always been very accurate when compared to the calculated average.
