- Joined
- Feb 11, 2006
- Messages
- 9,685
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2024 Miles
- 008131
- STOC #
- 6651
I only have 600 miles on the Michelins now but I have some initial comments. The PR2's are more nervous than the Storms and I found myself oversteering at tip-in and having to push the outside bar to correct the line after corner entry. This is not a problem just an observation and I have adjusted to the quicker tip-in. I was scrubbing in the tires of course and taking it easy to start with. In the dirty air of 75+ mph traffic the PR2's are less stable than Avons. I am running 42/42. I touched a buck forty in clear clean air and the PR2's did track true with nary a weave but the Avons over 120 might or might not weave depending on load or crosswinds so this one time event last weekend may not hold true under other conditions. More will be revealed.
Tonight I was looking at the PR2's very closely and noted the chicken strips were wider than I would normally see on Storms after the same roads. I have a spare set of Storms so I measured the width of the tire tread surface from shoulder to shoulder. I was surprised to find the front PR2 is 6 5/8" and the Storm front was 6 1/8", some 1/2" narrower. The rear PR2 was 8 3/4" or 3/4" wider across the tread. The Michelins have a bit more tread out at the edges which is a nice thing I suppose. I never got past the edge of the Storms but I guess the Michelins still have a little more left when leaned to the same angles.
