bplandis
Started on this a little while back with Larry, just before he went to doc. I have left it sit since and dug in today again. Is my dads bike that was shipped to me. Sat outside under a cover for two weeks. Brakes worked ok prior to it sitting under the cover outdoors. I only rode it a few hundred yards down the driveway from the truck to the house before it went under the cover. Did not notice them dragging or anything but could have been.
After the two weeks under cover, rear was 90% seized. Cracked the rear bleeder on caliper and it would spin. Still dragging though.
Pulled front and rear calipers, cleaned them up and reinstalled. Proper bleed, but still dragging front and rears. Can hear them on rotor. Has been sitting inside garage for about 3 weeks, pulled it out today and rode it down driveway and back. Rear is locked up again. Cracked rear bleeder and frees up, but still not all the way.
Any idea what the cause(s) of that rear locking is? Or is it the old 20+ step process to try and narrow the exact cause down?
Regardless of cause:
Going to rebuild back caliper as it needs it regardless of issue. Rear caliper pistons have some pitting in them. I used para cord and brake fluid to clean them up. Will also replace the rear bracket sub assembly and new caliper bolt (14 mm head) and retainer clips and spring pad as well.
SMC was replaced in 1/21, as well as rear pads , rear bracket (was spiraled) and all clips/retainers. All Honda parts. Brakes bled last season.
