I was out in the wilds of Arkansas yesterday riding around and stopped in Kingston, AR for some water. Once it was time to go, I hit the start button and all the instrument lights and my radar detector went dark, with no associated turning of the motor. Letting off on the start button, all the lights in the instrument cluster came back. I recycled all the switches (ignition, kill switch, turned off the GPS) and tried again with no luck. Sitting there for a couple of minutes trying to figure out how I was going to get the bike back to Fayetteville, I thought "maybe" bump starting it would be possible. I turned the bike towards downhill and before trying the bumpstart I hit the start button again. The bike started, so I elected to end my ride early and hightail it back to Fayetteville.
Once I got home I started and stopped the bike numerous times with no issues. I took the battery over to the Honda dealer in Springdale and had them put it on their diagnotics machine, but it came back as showing good. The bike is an '09 that I bought new in May 2010, so the battery is at least 3.5 years in use. It is always put on a Battery Tender Jr. when not in use. I ride the bike about 3500 miles a year, as it is kept at my vacation property. I ended up buying a new battery (Yuasa YTZ 14S)and some fancy Naco Genius charger to keep the battery charged during the long times between use.
Has anyone had something like this happen before, and was it indicative of the battery starting to die? Was it an internal fault or some other malady that maybe did not require replacement of the battery?
Thanks for any info you can share.
