coupla times? Just turn key off... also Works!..had to jump a coupla times because I left the key on, etc.... Works!
125 amps give or take.How much current does your starter motor draw when cranking the engine?
I am not really sure what you are referring to as the wiring harness being discussed is not a standard coax or SAE pigtail. It is a heavy # 8 AWG wiring harness that is specifically designed to be connected directly to a power-sports battery and is intended to be used for boosting those batteries. It does not have an in-line fuse, as is the case with any standard booster cable. There are no fuses in a starter motor circuit. There are fuses in the circuits that control the starter motor function, but not the starter motor circuit itself.Not exactly; depends where in the circuit you are measuring the load. CA/CCA is rated battery draw for 30 seconds - the starter motor is drawing about 3-4 amps steady, can be as high as 8-10, for a millisecond or two it might reach 125 or more, give or take. Most starter circuits have 15-40 amp fuses and relays are rated at about 60 amps.
It's all magic, smoke, and sparks.
Tom
My electro-babel deleted.I am not really sure what you are referring to ...
I haven't looked at them in a very long time but I seem to remember that the connector was unique to Noco and required this adapter. I don't have one to verify this however.I think Andrew is correct as is looks like they use an adapter to mate the x-connect (which is what the normal charger is) to the boost connect.
