I agree with Dwalby...
Honda recommends a visual inspection at 60,000 and change at 90,000. I say do a visual inspection at 90 and if it looks okay, change it at 110. I expect a visual inspection at 90 would'a showed the problems with that belt.
I've said for a long time I suspect most belt failures are predicated on a failing bearing in one the pulleys or gears. If they all check out upon the eventual belt replacement, they should be good to near 200K. When I changed STick's belt the first time (at 83K, in 96) it was because I assumed the 90K recommendation was legit and I was leaving on a long trip. The original belt even
looked new, printing was 90% as bright as the replacement. She got her third before 200,000. It's a used belt out of a wrecked 91 which had ~30K on it. It now has closer to 60K.
LipSTick got her second at 110K, the new one is a Gates brand sourced from Amazon.com. Saved about $30 compared to OEM and many of suspect Gates makes the OEM belt anyway. The belt is unique and even Gates lists no other use for it.
Anyhoo, good for the OP for catching this before a catastrophic failure. Hope your bearings are up to snuff but I think I'd be double checking.
