I was doing a fork oil change yesterday and noticed something strange. The damper rod was not centered in the top of the right fork's stancion tube. I then rotated the tube in the slider and noticed that the top of the tube did not rotate in place. I checked out the the exposed length of the tube with a staright edge from the dust seal to the top, and it seemed to be about 3/16 inch from straight. (that is a lot)
I checked out the other tube and it was about 1/8 inch from straight. I am thinking that the bike was wrecked before I bought it. The previous owner said "it was never down as far as I know." I have put 18000 miles on it and hadn't noticed any steering or suspension issues. I think the only real way to check for servicable limit is to disassemble the darned forks and check runout on the bench. Am I wrong?
I turned the tubes in the tree so that they are aligned with the bike rather than left or right. At least that way the wheel wont lean as the forks compress.
Does this sound potentially disasterous? Anyone know where to get some good used forks? (2003 ABS)
