91 ST1100 was sitting a long time. Prev owner said he avg'd 300-500 miles a year for the last 5 years. And boy have I paid the price in frustration, money, time and energy.
But on the positive side, I have learned an aweful lot and made lots of new friends along the way, meaning you guys.
A special shoutout to Jed Gregory (juddspaintballs) for his time over the weekend in getting the carbs ironed out. We got it done. Excellent teacher.
A special thankyou to Mellow for sending his carb sync meter, which arrived just in time to finish the job. Thank you Mellow.
So what has been replaced since May 2013:
- fuel pump and filter
- bottom of gas tank repaired along with a tank liner material (had pin hole leaks after the paint wore off) Honda defective metal
- new spark plugs
- #40 jets and lots of cleaning. Some other small parts (carbs are now purring)
- new front and rear tire
- new front pads and rotors
- new forks seals
- all fluids changed
- new thermostat
- new water joints along with the major water maintenance service
- new rear wheel o rings and moly
- tighten up the bar risers (jb weld on the bolts going in to the risers, they kept spinning from being stripped over the years)
- the blue Honda fuel stabilizer liquid (3 tanks full) which cleared up the high speed bucking/hesitation issue
I can now say with all of your help over the last few months, I finally have an ST1100 that runs properly.
Upcoming projects:
- alternator has already gotten stuck but is currently working but may be on its' last legs (lights also dim w/blinker on)
- valve clearance check
All plastics are now getting a custom paint job since prev owner obviously used a paint bomb on the pieces and it was horrible. 3 different shades of the same color. I can't wait to get it all back together.
- new spark plugs
- new forks seals
- new thermostat
Upcoming projects:
