uneasyrider said:
This is what I want to do, does the Kenwood use 12 volts right off of the bike battery or does it need to be reduced?
If you have the Autocom system, you run the radio from the intercom system and not directly from the battery. If you have an Autocom system, then I may be able to help but if it is another make, I would not like to advise you. Your radio would be powered via the intercom system as power is reduced and sorted for you, I would not run a radio directly from the bike battery myself.
Some of the newer Icoms and Kenwood radios have drop in chargers to recharge them, but if your radio, be it Kenwood or Icom, has a 12volt input socket to recharge, then you are cooking on gas, because you can use the input socket topower the radio from the bike eventually.
I know, it sounds as clear as muddy water, but if you have drop in chargers for your radio and not a DC input socket, you are stuffed basically. Some Icom radios like the ones I use, when you remove the battery, there are two connections, pos and neg, you get the power lead from Autocom and hey presto, radio is bike powered, you just connect the Autocom power lead.
Take the battery off your radio and look see if you have the pos and neg screw terminals. Also look see if you have in input socket to plug in your charger for the battery. If you have either one of those, we can go further, a DC input to charge the battery or the terminals is what you are looking for, if you have, then I can help and if so, I will call Autocm UK and have words with them about the leads on your behalf, and if needed, I will get them and send them over to you.
Sorry it sounds a little long winded, but if we can get it right, and I can help you, I will. Autocom is about 50 miles South of me, and they are normally very helpful, plus, if I know what I am after, they will make the leads for me.
Phew, time for bed said Zebedee, if I sound a little gobbeldy gook, please excuse me, my brain hurts at the moment LOL. I am in the process of taking over another company so I do not know if I am Punch, Bored or Countersunk at the moment!
Have a good one.
