Brackets ST1100
Erdoc48
94/00/04 STs, FSC600
I’m trying to visualize how it would fit on the ST- any pics with it next to the mirror to see how it looks? Also, you speaking about the one set or mass production?
Montreal
2009 ST1300A9
Below will give you an idea.
Uncle Phil
4 ST1100(s)
002064
698
You remove the little 'tab trim' and they bolt into the mirror bolts and stick above the mirror cover, IIRC.
Ron
Orlando
ST1100s
2432
I think they fit between the mirror housing and cowl spacing the mirror out 1/2"-3/4".
EDIT-Hound clears it up below. The light bracket goes outside the mirror bracket attachment points.
The right side is no longer available from Honda. The left is at available at about $55. Maybe find the right at David Silvers.
https://www.partsfish.com/oemparts/a/hon/506c18c3f870023420a2eafb/windscreen #15 and 16
JJames
Norway
2000 ST 1100 ABS II
There great . Solid mount to the fairing frame. Here with ramball/gopro mount. You have to remove the middle section of the plastic on the mirror housing ( no cutting) , and can be reversed/put back without any problems
Wisconsin
1994 Honda ST1100
I made my own. Honda only has the right side mount available. I believe it was left bracket that was discontinued. So, I bought the one side that was available as the template and made a complete set.
Hound
Cave Canem
Wales, UK
2004 ST1300PA
4607
The RH one is still available at CMSNL but they only have two remaining.
There's a pair of ST1300 brackets on eBay UK.
