- Joined
- Mar 18, 2006
- Messages
- 2,832
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
This might seem like an odd problem coming from me. I know my way around the brake system of the ST1300 probably better than many ST1300 owners. Yet this little issue came as a big surprise.
It's been 2 years since I serviced the brakes properly - except for fitting new discs all round last winter, and new pads and a casual flush through, so I thought I'd have a thorough check over. Nothing was wrong, but after 70,000 miles and spring showing no sign of arriving anytime soon.....
So SMC came off, and I separated the caliper from the bracket. I had suspected that the caliper wasn't sliding properly. Popped out the nylon cartridge and checked the tiny compensation port, and ran a 0.012" wire through it - with a bit of effort. Popped out the pistons to check for the state behind. All Ok.
Did the usualy clean of pistons all round - without popping the others out, cleaned and reseated springs, clean slider pins and boots. Cleaned fairly new pads and pad pins.
Then reassembled, new crush washers filled up and throughly bled. My first time without using a vacuum bleeder on this bike, and that all went well.
Everything was rock solid. I was pretty pleased.
Now I don't know what happened after that. I had been putting things back together a bit at a time, popping into the garage whenever I felt like it. So everything was left loose for a couple of days (except the bleed valves and reservoir caps. I know that I lifted the caliper off the front left to double check that I had torqued the banjo bolts. I had. I know that my axle bolt was tight, but I had left the pinch bolts until after I had taken the bike off the ramp.
Both wheels had been out to have new tyres fitted and the fairing was compeltely off.
But two separte occasions the lever pulled straight back to the bar. Once one day - thank goodness the bike was in the garage, but I felt almost as alarmed as if I had been moving. It took two pumps to gte it up to full tightness. Then it did the same two days later.
Both times I can convince myself that it was because I had interfered with the caliper - but I didn't think it was enough to push the pistons in - but I may have done - I wasn't paying attention to that, or I cannot remember exaclty what I did between getting a tight lever and it going soft. Certainly I bled the brake lines without the calipers or pads in place. I use wooden blocks to stop pistons flying across the garage, so the calipers and pads were fitted afterwards, and then pumped up to feel tight.
That was three days ago. Today I took the front calipers off again to check that the spring was positioned properly - I know it can interfere with the movement of the pistons - especially when pads are new. It can drop down below the piston and interfere with the movement. No they were Ok. This time I did move the pistons. So tthey needed pumping out after I had repalced them.
The only thing that I can think of is that the centre piston was never pushed out all of the way - perhaps on the right side - which is subject to the delay valve, and somehow this had affected the alignment of the pads. But I don't think so - the lever was tights and had a really solid feel when squeezed hard.
So I am reasonably happy that I propbably did something to disturb the calipers/pistons on both occasions - without realising. I certainly cannot rule it out. But I wasn't working methodically - sometimes I was takinging a 'shortest job first' approach - so bleeding the rear line came last. But I'm not convinced. I'll find out when I take it out for a test ride.
But can anyone think of anything that I haven't thought of that would cause this behaviour.
