brake pedal travel 2009 ST1300 ABS
Albany Western Australia 6330
Hi, just completed a major overhaul of the brakes and after trying a couple of rear ST brake pedals, I think I have a little too much travel. The pedal is firm but travel distance appears to be excessive, any advice, cheers, David
010688
It can be difficult, no not difficult but tedious perhaps, to bleed all the air out of the proportioning control valve and the secondary master cylinder but air in that circuit can cause a soft pedal and/or the "pedal drop" that occurs when both hand and foot brakes are applied and the hand brake is released while some foot brake is still applied. Their are plenty of resources in this forum regarding brake bleeding including this thread. I can also send you a system flush and replacement PDF file that I find easy to follow. PM an email address if you want it.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
Sounds like you still have air in your system, try to bleed the system again following the links here in the proper order.
Hi all, many thanks for the replies and advice. The bleed went well and I spent a good half an hour concentrating on the PCV valve. As mentioned, the pedal and hand brake are firm, I was just wondering how much travel there is roughly on the pedal, David
1&2&3-2005 ST1300ABS
001862
8562
Dave, just arrived home from a ride. I haven't went out and measurd the travel, but just guessing by my foot movement, it would be in the range of 25-35 mm. (1" to 1-1/4")
010688
My rear brake pedal travels 13mm maximum so it begins to apply brake pressure at maybe 6 or 8 mm into the travel.
