Good Luck... that's all I have to say....
I had some time today and decided I'd take off the 023 and put on an 020 to see if the unigo would still have a wobble - that way I could at least dismiss it as a tire issue.
Well, the sidewalls on the 020 are known to be some of the stiffest around... I think the ones on the 023 are the softest around.
I say this because none of the previous techniques I've used on my 100s of tire changes with the no mar worked just to get the tool into the 1st part of the tire once the bead was broken. The sidewalls as so soft, the inner diameter of the tire hugs the rim... eventually, I was able to jam a screwdriver between the lip and inner rim to get just enough open and get the tool in.
After that, the demounting process was the same as with other tires...
Just be warned, you might be in for a war... It might help to have two people around...
