Broken Rear Frame
Scotland
Just wondered if anyone else had come across this. I bought my ST1100 last August and the tail has always been a bit rattly - I put it down to a loose Givi top box mounting. However, last weekend I was doing a bit of fiddling and discovered the rear frame extension was broken. This supports the tail piece and grab handles. Difficult to imagine the weight that must have been on the rear rack, and the size of road bump that would have caused that shear. And no other part of the bike damaged?
STraymond
Cincinnati Area
'01 ST1100
8700
Mine broke in the same spot. My Givi 52 liter topcase definitely had a lot to do with the metal failure. I have just installed a new one, but am switching from the Givi mounting plate to an alternative rack that will move some of the topcase load off of the new plate.
West Michigan
'98 ST1100
8470
:plus1: !!! I just discovered the same problem a few weeks ago. I also have a big Givi case installed. I removed the bracket and welded it back to gether with my MIG welder.
The question I have is : Why does it seem to break on the same side of the bracket ?
Lexington, KY
1998 ST1100
8643
Maybe it has to do with the side stand being on that side. The force of the weighted top box leaning towards that side over and over again. Although, my uneducated brain could argue that the other side is stressed equally yet opposite, so I really have no clue if this theory has any merit or not...
British Columbia
2021 RE Meteor 350
The OEM topbox that was available for the 1100 in early years had a maximum load capacity of about 20 pounds. Might have been a bit less than that, but can't remember the correct number. Putting more than that in a Givi or otherwise, which would be heavier than the OEM box to begin with, is the reason these things break. One thing that could possibly be done to strengthen that part would be to weld a couple pieces of thin steel plate onto the outsides of the arms over the large hole area.
Seems like a guy handy with a welder could reinforce the brackets easily enough as Jim did. But really who never exceeds the load recommendations for bags and boxes.
Has anybody preemptively reinforced the brackets?
STraymond
Cincinnati Area
'01 ST1100
8700
West Michigan
'98 ST1100
8470
Well, I didn't really reinforce it, I just repaired it. I had an IBA SS1K Ride to do the next day and didn't have much time to spend on the job. But in the spring, I will remove the bracket and reinforce it with a few small steel plates welded across the holes where the cracks developed. And I'll do both sides, to be on the safe side.
RobbieAG
Robert
Greensboro NC
I've been concerned that my Givi box mount doesn't seem that sturdy for a while. What do I have to remove to see if I have this issue?
West Michigan
'98 ST1100
8470
The saddle.
:plus1: To inspect.
To remove & repair, then additionally the saddlebags, side covers, top box mount, and the plastic cover over the tail light. Doesn't take long at all.
If one side of the top box seems a bit looser than the other side, you probably have a cracked bracket - easy to inspect.
RobbieAG
Robert
Greensboro NC
The saddle.
Well, that was easy! Thankfully no sign of cracking. It does seem that it would be best to not put a lot of weight in the top box. On camping trips, I put all the light stuff in there. When I commute to work, I need to put my laptop in it - it won't fit in the saddle bags. That might be pushing it.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Check the 4 8mm bolts that fasten the Center Plate to the frame (see the Seat Cowling schematic, p.2-3 in the manual). Following my friend Bill on one of our WeSTOC trips I noticed his Givi sagging on one side... missing bolt. Trip to a local hardware store fixed him right up. Hell of a mess in the motel lot getting to the bolt hole. :)
Mine says DON'T PANIC! But I do.
Excessive lateral forces would weaken the rack over time especially with something heavy sliding around in the trunk. But unless you have a 70s-80s "portable" computer (Osborne anyone?) a 5-6lb laptop strapped in place shouldn't push any limits. But if it breaks your bracket I don't know you and we've never met. :)
The saddle.
+1...
And I'd regularly inspect all 4 bolts holding the subframe to the backbones for proper torque, as their known to come loose over years and years of (too heavy) topcase-rattle...
A torque wrench and a drop of thread-lock deals with the issue ;-)
The easiest (and FOC!) countermeasure seems to keep your topcase payload at bay and within the MFG recommendations of 6.5kg/14.3lbs nett or 10.0kg/22.0lbs gross weight...
(brief observation of driving physics should prohibit one from placing weight that high and that far aft on a motorcycle anyway; heavy stuff is to be packed as low and forward as possible...always...)
And IMHO is ST Gui on the right track with his remark about lateral movement (shape and kind of material fracture enforces that argument):
cracked subframes seem to occur almost exclusively due use of unsuspended after-market topcases/racks, whilst I've never seen one coming apart in such matter when an OEM carrier plate with lateral damping is installed; food for thoughts...
Last but not least my very own experience in this issue:
- I'm using the OEM carrier plate with lateral suspension
- I never leave the topcase on the motorcycle when not needed/riding solo/commuting...
- On tour I only pack the very lightweight items there: his/hers thermal liners/fleece-jacket, spare gloves, balaclavas, a hand full of road-maps, mandatory roll of toilet-tissue/wet-wipes...
never suffered a broken subframe ever... go figure...
RobbieAG
Robert
Greensboro NC
Everything seems snug but it flexes more than I'd expect. Both sides flex equally. I do think it's worth having a look to make sure all the bolts are there and torqued properly. When I put the same box on my 1300 it seems more solid (less flex).
