I just finished changing my rear tire out as the 020 was almost to the wear bar at 13,300 miles. I put it on new just prior to leaving for westoc last year. Shortly after westoc with only about 3K on the tire I picked up a nail and found the tire flat. Being that I never tried plugging a tire before I thought this would be a good time to try it. I used the gummy worm type plugs found at wallyworld. The tire never leaked a pound of air from the patch as I made sure to check it often. I found that after I removed the tire and looked at the inside where the patch was that the gummy worm had made like a mushroom head against the inside of the tire, I'm sure that heat combined with centrifical force caused this to happen. With just over 10K on the plugged tire, a trip to cheapstoc included in the mileage, I fine the gummy worms to be an effective means to at least get you to a shop or home as long as the hole isnt to big. Pictures of the tire and the patch inside included. :biker:
