I'm looking for a new tires now and just wonder which ones is better (last longer, comfort). Thanks.
Nah,You better take cover.......cause you just smacked the hornet's nest with a stick.
Better handling??I liked the 021 over the 020.
Oh....good point. I just saw a tire question and instinctively hit the deck.Nah,
This one should be easy, comparing just the 020 and 021's..
Lets keep it simple folks, anyone have a comparison between
these two tires??
Putt...
I was right there along side ya when I saw the title...Oh....good point. I just saw a tire question and instinctively hit the deck.
You stopped in and didn't say "Hi"? (At least I don't recognize your name/avatar)I recently purchased my first set of 021s from SoloTotoCoyote's shop, I have about 1000 miles on them. Only thing I've noticed so far is that the front tire doesn't seem to be as "progressive" as the 020s when breaking loose in an emergency stop type situation. The 021 breaks loose more sudenly than I remember the 020s. I had two sets of 020s both wore out at 6k miles. Yet to see what I get with the 021s.
Did you have them installed here or did you just buy them at take them out? (Trying to jog memory)Kind of. It was the morning that SuperSabre was down so things where a little busy.
Ok.....Now I remember you!!! Sorry about that. I was killing myself trying to remember seeing another ST come through for tires and completely spaced the loosemounts.You folks were good enough to mount and balance the tires for me. I had them off the bike. You asked if I was familiar with the forum, I said that I was but didn't spend a lot of time on it. This is the greatest place to find out what you need to know!
That's an ugly tire. Does anyone know if the other dual compound tires suffer the same odd wear patterns?I'm on my 4th set of 020s. I had 1 set of 021s.
The 021 feel fantastic...for the first 3k or so. Because of the dual-compound, they wear rather oddly and right away get to feeling scary. My 1 set was put on just before the 3 Flags rally (5k round trip), on my 1100. When we got to Canada, a friend on an '05 1300 showed me his front tire. He only had 5k on it, but it was toast. Totally smoked. He did make it home (Medicine Hat to Vancouver), but he was tentative the whole way. Mine only had 3500 mi on them at that point and were starting to look the same way with the odd wear pattern (high, square "lump" in the middle of the tire). By the time I got home, they too were toast. And the worst part was the handling anomolies. The bike fought to go into a turn, then wanted to stand itself up the whole time. Until that is, I went deep into a turn, then it would all but fall over. Aweful aweful feeling, especially with the wife on the back at this point. I had to shave the rear 1/2 way through our ride back home, it was getting so bad. But, YMMV!
Here's a photo of a "typical" BT021 with not all that many miles on it:
