I have to do valve adjustments and the camshafts have to come out. In the service manual it first says to line up to the "T1" mark (for the left side) when I do this the index marks on the sprockets line close to how the picture shows but not exactly even. Just a tinny bit off, is this normal?
Also it then says to rotate 360 degrees to remove the other cam sprocket bolts, I am not removing the sprockets from the camshafts so do I leave it at the "T1" mark for the remaining steps? OR do I rotate it the 360 degrees?
