Carb air intake in the airbox
Vancouver, BC
1999 ST1100AX ABS II
Hi all,
Would you please take a look at the photos and comment whether it looks normal or not. My concern is the presence of residue. I don't know what it could be other than sprayed fuel?
Thanks very much
BumbleBerry
Vancouver, BC
Thanks John. I shall take a photo of the air filter and post it here. It looked rather normal (with small particles and dust trapped in) with an exception of a small dirty dark gray area.
East Anglia, England
ST1100X
#1702
It's quite wet in there! Did you happen to lay it on it's side or overfill the oil? The engine breather is the only source of oil and there is a baffle that stops the residue getting straight on the filter.
BumbleBerry
Vancouver, BC
Thank you all.
The oil level is right in the middle. But a year ago, for a while, she ran with oil level just above the top mark. Oil was changed few times since and always in the middle.
So I guess, it was because of that one time. I am waiting for new air filter too.
My concern is that BumbleBerry has lost ability to hit 160 kph and beyond. She just can't deliver. As you all know, ST's can easily hit those numbers and I intentionally watch my speed so I don't go above speed limit. But for a past 3 weeks, the power is not there at all. She barely hits 140.
She starts fine with choke, idles perfectly, but on first and second gear sort of rides with a hick-up! Until she warms up a bit more and at top gear in high way, can't go beyond 140. I have filled up with 94 octane fuel (always Chevron) and she performed a bit better. Battery is functioning perfectly, regulator/rectifier is fine (I tested both as service manual). I rode with gas tank cap removed, not change.
I don't have much hair left on my head to pull, so I keep scratching my head!
Sunday Rider
Aurora, Ontario
1997 ST1100
6136
Have you synched the carbs lately? How do the spark plugs look? Is the air filter clean(I know you ordered a new one)?
If this has just happened recently, and not gradually, one possibility would be your ignition coils have gotten weak.
Another possibility would be fuel delivery is adequate for lower speeds, but at higher speeds its not able to supply fuel at the necessary rate.
Since either scenario isn't a hard failure, but rather a degradation from normal, its hard to say how to troubleshoot for either condition. Ignition coils can have their resistance measured, but I'm not convinced that tells you much unless one isn't working at all. Weak ignition could show up as a fouled plug, worth taking a look.
I think there's also a flow rate test for the fuel pump, but I've never done it, perhaps someone else will chime in with their experience. I know there's been more than a few replaced fuel pumps being discussed here over the years.
woodinville wa
Ditto on the plugs, and check fuel filter too, could this have started right after a fill up at the gas station. while the pugs are out check the compression to split the troubleshooting between a mechanical problem from a fuel problem. Timing can also cause this problem, 1100s have a timing belt too, might be due an inspection.
kiltman
Stratford, Ontario Canada
2002,ST1100ABS
8826
Check the routing of your throttle cable, make sure it isn’t snagged under the air filter housing
I'd suspect this:
Small tare in the diaphragm of the auto fuel valve, preventing full opening of the valve core...
BumbleBerry
Vancouver, BC
Thanks very much for all your inputs and great ideas.
I feel so dumb now, because the problem was much simpler than I thought! And the cause was a dirty air filter!! Last time, I changed the air filter back in July 2021. But I didn't look at my maintenance logbook, and it didn't seem to me that long ago. So once I got the air filter (HiFlo HF1911) opened the air box and cleaned it, and look at the air filter :
Put the new air filter in, and the oil/filter were due, so changed those, too.
She's back as normal, so we went for a 1000 km day trip!
