Well, I've no info about the avail supplies in Russia, but here in central Europe is no such thing as Sea Foam avail...
The automotive suppliers and hardware stores do carry some fuel additives, "mileage improvers" and "EFI system cleaners" by STP and such MFGs, so one needs to seriously search for a true carb cleaner additive...
If all fails one must go with the DIY home-mix with Isopropanol, Petroleum and others (recipe is avail in the Inet)...
Another issue could be general fuel quality; again do I miss any first hand experience with Russian gas stations, but I had my issues with Czech, Slovakia, Hungaria and all around former Yugoslavia... fuel in all named is know to be generally contaminated, often having a high water content... (I managed to seize up the injectors of my company car over there, according to my workshop where the needles rusted up like been recovered from the bottom of the ocean... must have picked up some wet fuel...)
So to complete the chain here: lets also focus on bad fuel and all the symptoms & efforts connected with that.
I'd go systematically, step by step:
- inspect the inside of the tank, the bottom in particular, for debris/contamination...
- check the fuel filter, replace if required
- check the diaphragm of the auto fuel valve, a rupture can cause intermittent stops in the fuel supply.
- check the carb boots/isolators, as well as every other vacuum sided hose and line for cracks or leaks... drawing "false air" is always a problem and would fit the symptoms...
(note: SC26 engines do have a PAIR system; due this their known to produce some silent rumble while coasting/deceleration with "engine breaking", but that's only a soft "blum-blumblum-blumblumblum" in the exhaust, no sudden bangs, no misfire and no bogging connected with that; and ST1100 is always smooth as an electric motor... )
- there is no general mixture adjustment on CV carbs; their factory set by main-jets, and that usually works perfectly...
- only the idle jets offer a mixture setting, this should not cause any issues during operation, only causing problems in idle, maybe issues during gear changes, but no bogging at acceleration...
- opening the carbs for cleaning/inspection could be risky due to a slow supply on spares over there, but depending on evidence collected in tank and fuel filter it might be unavoidable.
The issue is that you'll likely need new gaskets once you open the carb bowls... but you might need to for cleaning the bores of the jets.
Same when inspecting the carb diaphragms, they might have swollen in size/diameter (fuel quality, ethanol additives, etc...) so once you've opened the top covers, new diaphragms are due...
If the engine shows bogging, backfiring and such, something is off...
Also possible is an intermittent contact on one or both ignition coils (bad crimp, corrosion, etc...), which are located behind the steering head.
When already diving into there, give als the big mains connectors (LH & RHS switch pod, and ignition lock are joining the bike's mains harness there) a visual and cleaning/protection with a designated solvent (no WD-40!! Some proper contact cleaner/care product; ACF-50 is great in that regard)
The spark plug looks good so far, but it still could be that one has a cracked isolator, causing an intermittent "shunt" thus lack of spark on one cylinder bank (like when water has filled up the spark-plug holes underneath the caps after washing; the still cold engine coughs and bogs with that, once warmed the water evaporates and the symptoms are gone.
