Hi, im after a little advice on my carbs if anyone can help at all please. Its a ST1100AX 99plate UK model.
I have stripped them down and thourougly cleaned them with carb cleaner and compressed air and put them all back together. The only thing i did not do was split them apart. I did however manage to get all four air-cut valves out before cleaning to avoid damaging the diaphrams.
Q1On rebuild i noticed that the choke linkage bar has a little play in it making carbs 1 and 3 uneven to 2 and 4 (the control side) opening slightly after and a little less untill full choke. Has anybody come across this previously and if so how did you resolve it?
Q2 My idle adjustment screws range from 1 turn to 1 and a 1/4 when checked before removal which seems a little odd. My Trusty Haynes Manual says "Initial setting 1 and 5/8 out then Final setting 7/8 out (see text)" Guess what no text apart from the general information which basically says if unsure take it to Honda. Any Ideas on this?
I dont really fancy putting it all back together to find its wrong and have to start again. I have already bench set the butterfly valves and will do a full sync when back together.
