I was just looking to see what others had done with carburetors, looking for additional HP. I found a great 2002, but the roll-on speed lacks punch.
Down shifting will help a bit, if you need some extra speed when passing.
If you want more "punch", then get a ST1300. I put an electronic cruise control on my ST1100 because the ST1100 is so smooth, I was spending too much time watching the speedo. My speed would creep up towards 90 mph on the slab.
The thing that has kept me away from looking at a 1300 is the reports of engine heat issues. This is why I was looking at the 1100.
I think a lot of the heat issues come from one of the virtues of the ST's - stellar weather protection. If it rains, the bike protects the rider from all but the heaviest downpours, and unfortunately, it also blocks most of the wind on hot, dry days. That said, the bike is so smooth and gives me the feeling that it will run forever.
It could be the bike is as good as it will get .But it may also be a little down if servicing has been neglected. Decent fuel also helps a little.
But like they've all said it's for 100 mph all day not 100 mph in 4 seconds.
Personally two up and loaded to the gunnels I think it's fine. The bike equates fully loaded to about 200 bhp per tonne, i.e. the bike won't be far off 500 kg and it puts out about 100 bhp.
If you want a steady tourer that can also scratch a little look no further. If you want the front wheel in the air look elsewhere.
I'm a poet and I didn't know it.
Upt'North.
I have also thought that a 1100 would be a safer life alternative than having crazy power.
I have never had an engine heat issue with the 1100 (unless you leave the glovebox panels out) but the screen is too effective in hot weather, and even vented jackets need some airflow to work. My solution was to use a sporty screen for summer but I can really see the appeal of an adjustable screen like the 1300 has.
That's exactly what I do is put the stock screen back on in late June and run it through September. Then I put my 22 inch screen back on October and I'm good until next June/July.
Well there you go. You can't have it both ways, so you need to decide which desirable characteristics you value the most.
I have never found the 1100 to be a slug when asked to get by a semi on the highway. Get the gears down to #3 (or about 4,000 RPM) approaching the rig and then whack it to pass. Pulls strong and hard for me and I can hit triple digit speed (the ton) in no time. Seriously, what more do you need?
Plus one on that.Well there you go. You can't have it both ways, so you need to decide which desirable characteristics you value the most.
