JLamb
1991 ST1100
Can the carb diaphrams be checked without removing the carbs?
It is normal to start the 1100 with full choke. Should not have to run it very long on choke, and the idle should go up past 2K when it starts warming. Sounds a lot like clogged jets.I need to use full choke, no throttle when cold to start the bike
So does balancing the carbs cure this lean condition,I think you have just described my bikes exact condition,also at 39,000 miles should I also get the valve clearances checked?First, since the bike has good power, there is nothing wrong with the carb diaphragms. If they were torn the bike would have no power above 60% throttle. 2nd, since the bike needs choke to start even when not really cold, this is a symptom of a lean condition. A lean condition will also cause lower fuel milege. I'm guessing that the 1600 rpm idle when warm is with the choke off????? If this is the case the idle is too high and the carb butterflys are too open which can will lower fuel milage. Warm idle spec for US bikes is 1200rpm + or _ 100 rpm.
My fuel mileage on my '91 has always been in the mid 30s to very low 40s . 39mpg is spec on Motorcycle Consumer News tests and othet spec sheets. I've never figured out how some get 50mpg. Larger than stock windshield will cut the milage.
$8.75 from Ron AyersWhere do you get the $9 isolators? Doesnt sound like a Honda price!
