Hi Guys,
I became a proud owner of an ST1300 and I love the bike!
Unfortunately I have issues with the clutch. I read many if not all of the post in this regard but my issue is a bit different than the others.
Here is the story - All fluids(brake, clutch, motor oil, coolant) and filters(Oil, Air) have been changed 3000KM ago. The issue with the bike is that every time i change a gear I can feel with my toes and hear how the gears are biting on their teeth.
It is like I'm shifting without the clutch engaged. This happens through all of the gears, both up and going down(more noticeable going down). 1st gear is especially bad as when I shift into first I first hear a loud GRRRRRR and then it goes into gear. The situation is the same for both hot and cold bike. I'm forced to start the bike with the clutch engaged and on 1st and to downshift to 1st prior stopping and then holding again the clutch to avoid the teeth of the gearbox being abused.
When I have the bike running, the clutch pulled and the bike is in gear(1st) and no brake is applied the bike doesn't move forward, however if the bike is cold, in gear and not running i can feel resistance when I try to push it forward.
I tried putting the bike in 1st, applying the brakes and slowly disengaging the clutch and the bike stalls, which I think shows that the clutch still has life in it.
P.S. I have also lubed the gear lever as advised in one of the threads- didn't help.
Please let me know how to find a cure for this as I'm worried not to damage the gears.
Cheers to all!!
Cheers to all!!
