- Joined
- Mar 18, 2006
- Messages
- 2,832
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Definitely. The old fluid in there isn't going to shift a great deal under normal operation. You want to be rid of the old.Should bleed it at the slave also to get rid of the old fluid....
So --- Top up the reservoir, bleed tube on the bleed valve on the top of the slave. Pump up the clutch lever - and hold it in. Open the bleed valve slightly and let the returning slave cylinder piston and the fluid pressure gently push the old fluid out. Close the bleed valve before it stops flowing.
Repeat. Pump the lever a few times to push in the slave piston - to mix any remaining old fluid with new inside the cylinder.
Repeat. Repeat. Keep an eye on the master cylinder reservoir - remember that this process is removing the volume of the slave cylinder every time. The reservoir will go down more quickly than normal.
If you just open the valve and pump fluid through, you are not getting the piston to move through the new fluid. This way, you eventually get a chamber full of new, holding the piston in, and then flushing the old out.
