IndyRob
This week my clutch started to not disengage when I pulled the lever in all the way. I checked the fluid level and it was fine, but quite dirty. I admit I have not regularly changed it as I should.... so I purchased a master cylinder rebuild kit online. My question to the group is; is it necessary to remove the hose from the clutch master cylinder on the handlebar to do the rebuild? The reason I ask is I do not think the kit that I purchased online comes with the 2 brass "crush washers" that the output hose uses, and I failed to buy these in addition to the main kit.
Can I get the springs out without removing the output hose? Or should I try to get the 2 brass washers ASAP?
Thanks!
Thanks!
