Hi there,
This web site has been a great help and resource for me, as a new rider. How cannot stress how happy I am seeing so many helpful people here, none that will put you down with ‘stupid’ questions.
That said, I’m learning and would like to ask about coolant, something that might be obvious and thus cannot find answers for.
so I see in the service manual that the coolant must be ethylene glycol based designed for aluminum engines. I prefer to purchase ready mix.
First, do you need to purchase coolant specifically made for motorcycles, if there is such thing?
Second, I assume the coolant color is supposed to be blue, correct? I tried to check the coolant in my motorcycle, and I don’t think I can see anything in the reservoir. I bought this 1993 ST1100 couple of weeks ago, and just thought of checking it.
Third, are there bad quality brands I should stay away from? My first thought would be getting a genuine ‘Honda’ coolant I see on Amzaon’s web site. Is ‘Peak’ an ok brand?
If possible, I’d like to avoid taking off the fairing to check the radiator cap, might need to? Suspecting I might concentrate on replacing the coolant all together…
EDIT:
There has been some ‘development’: I managed to open the radiator cap (nothing was in the reservoir), and it appears the coolant is green. I assume the coolants you recommended is blue, and should not be mixed. Furthermore, I tested the coolant and it shows only at -20F, or is that normal? Here in Chicago I think temperature can drop below that. I did measure when the coolant was a bit warm, after a short ride I took. Would slightly warm coolant give false reading?
Am I on the way to flush the coolant and put fresh one?
Thanks,
Doron
EDIT:
Thanks,
Doron
