I am posting up this file photo (not my bike),,, that shows the oil cooler lines passing under the throttle bodies and rubber heat barrier. I had a similar drip/leak,, early in the season,,, that seemed to be coming down the oil cooler hoses from above. Because I had tightened the clamps at the oil cooler,,, it seemed the leak must be higher up,,, perhaps coming from pooling in the valley. Anyway,,, as I was trying to determine the source,,, I let the coolant bottle level decline to just below the lower level mark. And,, the leak stopped.
This would indicate a coolant bottle leak,,, at that level. But why would the leak/drips be coming off the oil cooler. So I decided to keep an eye on it,,, and have put about 7k km's on it since,,, with no drips and running and cooling fine. Actually,,, my '04 runs a lot cooler than my 2012. So at this point,,, it's all a bit of a puzzle. I did buy a complete thermostat and all hose's ass'y (6k km's),,, from a recycler ($50.us approx),,, anticipating that I will be doing the major surgery at some point. If I had to replace the oil cooler line that you show,,, only, I would consider trying to fish the new hose through,,, before I removed the throttle bodies and such. Anyway,,, just wanted to add my observations in. I am not doing anything to BlueSTar at the moment,,,, as ThunderSTruck is getting the 5-way/tbs treatment. I need to ride one bike,,, in order to maintain some semblance of sanity. Best of luck with this, I am watching with interest,,, CAt'
@RichKat
