Hey guys, I removed all the Tupperware for a coolant change but I'm wondering about the draining procedure? I'm aware to drain the radiator by removing the lower coolant hose and also draining and cleaning the overflow, but I also see the SM shows removing the drain bolt from the right cylinder head. There's a similar bolt on the left side cylinder head aswell? should I be removing that to drain that side? Thanks for the info in advance!!
