After a ride this morning, I parked Moby in the garage, came back out little later and got a whiff of coolant. I know 1300's are prone to leaks, but where is a good place to start looking, coolant level is good, and just a faint smell of it
Pulled the plastic and looked all over, no sign of leak, my bike is a 2111, so maybe I should just change out my hoses, time for a coolant change anywayI had my share of coolant leaks, and they can be hard to locate. Your best bet may be to remove the Tupperware and look for signs of dried coolant (color) around the engine. My leaks turned out to be from the larger hoses that connect to the radiator. After changing the coolant I had a hard time clamping them tight as they were a bit dried out. I eventually replaced the hoses and that took care of it. If your leak is sufficiently large, some paper towel underneath the bike may show you where it's leaking - but in many cases the leaks are small and only there when you ride and the system is pressurized.
Best of luck.
Is there a suggested torque to which the drain hose should be tightened. That is the one that comes off the most. Folks are afraid to tighten it too much in order to not damage the metal part of the radiator.Tighten all....all the hose clamps before replacing your hoses.
Bet you find over 50% need a slight tightening.
T
Did you look at the thermostat housing? I had a weepy leak on the left hose (big one) - right side off the housing as you look at it with your head under the bike. It caused a little corrosion on the spigot that cleaned up with sandpaper. I also had a drip at the hose to radiator connection (again left side). Many guys simply tighten the clamp a hair. I replaced all hose clamps I could reach with constant tension clamps. Be very careful tightening the clamps on radiator spigots - the metal is thin and you can easily collapse the pipe.Pulled the plastic and looked all over, no sign of leak, my bike is a 2111, so maybe I should just change out my hoses, time for a coolant change anyway
If it turns easily, tighten it. I have never used a tourque wrench for things as small as hose clamps.Is there a suggested torque to which the drain hose should be tightened. That is the one that comes off the most. Folks are afraid to tighten it too much in order to not damage the metal part of the radiator.
Permatex 80019, answered way back in 2018 by @The Dan, post #21;I've mentioned this in another post and do not remember if a reason why sealant is not customarily used any more was posted.
I have that on some of my thermostat housing hoses.Many years ago I watched an auto mechanic spread black goo on the spigot of our radiator before he slipped on the hose and clamp. I'd guess it was a sealant, though I've used a small dab of silcone grease on the metal spigot to help slide on tight hoses. Not sure why we don't use sealant today...I've mentioned this in another post and do not remember if a reason why sealant is not customarily used any more was posted.
I would suspect this “goo” is used when re-assembling used hoses on possibly worn or out of round rad fittings. I guess this is similar to using tire bead sealant “black goo” when mounting tires on old pitted rusty rims.Many years ago I watched an auto mechanic spread black goo on the spigot of our radiator before he slipped on the hose and clamp. I'd guess it was a sealant, though I've used a small dab of silcone grease on the metal spigot to help slide on tight hoses. Not sure why we don't use sealant today...I've mentioned this in another post and do not remember if a reason why sealant is not customarily used any more was posted.
I remembered The Dan's answer that he had used it years ago. But if a non hardening sealer worked then why did it fall into disuse? Are rubber hoses softer and do they seal better today? Is one more tube/can of goop the first thing to go in a shop as costs (mat'ls and labor) rise? Job security? Small leaks in a cooling system are nothing to worry about?Permatex 80019, answered way back in 2018 by @The Dan, post #21;
Sealant on cooling system hose connections?
I can't answer that because I have never been a user of such products, and have never seen it being widely used. In all of the decades that I worked as a mechanic, I have never used any goop to properly seal a coolant connection except as a stop gap/emergency repair until the failure could be properly diagnosed and repaired.But if a non hardening sealer worked then why did it fall into disuse?
I had a hose break on a car years back (bought used). Chevy with a transverse mounted V-6. Bought a hose and new clamps and tried to remove the broken one...and tried and tried. Ended up cutting it off at the radiator and water pump, carefully sliced the remaining sections with a really sharp hobby knife, and spent the rest of the day cleaning adhesive from both fittings while trying to not scratch the surface of either. Back side of the water pump fitting was a real b&*^%.Many years ago I watched an auto mechanic spread black goo on the spigot of our radiator before he slipped on the hose and clamp. I'd guess it was a sealant, though I've used a small dab of silcone grease on the metal spigot to help slide on tight hoses. Not sure why we don't use sealant today...I've mentioned this in another post and do not remember if a reason why sealant is not customarily used any more was posted.
Mine does it when coldAfter a ride this morning, I parked Moby in the garage, came back out little later and got a whiff of coolant. I know 1300's are prone to leaks, but where is a good place to start looking, coolant level is good, and just a faint smell of it
