I noticed a drop of green fluid on the garage floor under my bike today while I was taking the tupperware off for some winter maintenance. On the right side of the bike, if you follow the fat radiator hose to the bike, it terminates on what I think is the water pump intake pipe. Immediately aft of the water pump pipe is a small, 1/4" tube that leaves the engine. This pipe seems to exit from the alternator housing casting (?); the engine block is behind this seam. A black hose is clamped onto this 1/4" tube and leads down under the crankcase and vents to the atmosphere. I looked in the service manual and could not find this hose in the cooling system section.
Is this a breather or drain hose? This is the source of my drip. There is no obvious other leak on the front of the engine (though I have not yet pulled the left tupperware). The bike is a 2010, w/ 24k miles.
