Cycle Gadgets finally has the Migsel RAM accessory shelf for the ST1300 in stock. Just ordered one and I knew a lot of you were interested in it, so just letting everyone know.
:worthlessJust got mine last week. Installed it for use with my Zumo 550 with GXM Antenna. I used the Cyclegadgets antenna mount cut off and just sandwiched between the mount and the ST bodywork.
This last weekend took an 880 mile roundtrip to California and the mount worked great. Put the Zumo up in my eyeline and the antenna and zumo are protected by the windshield.
If you travel on very rough road there is some bouncing but on normal road it is fine.
I like that hookup for the antenna. I mounted mine inside the dash, but I'd like to be able to take the antenna with the GPS to the truck. I have a second antenna, but with a different radio ID that'$ another $ub$cription.Here is a link to the Antenna Mount http://www.cyclegadgets.com/Images/RAM-XM30BRK.jpg
I had to rebend the mount and cut the long end in about 1/2 then I just sandwiched it under the mount and it worked great.
I cut the power cord to the cradle and installed a waterproof two position plug that way I can unplug power unplug the mic and audio out cables and take the cradle and antenna off and secure them if I wish.
Yeah, Since the antenna is big bucks I didn't want to leave it on the bike all the time. While the antenna mount has a couple of holes for screws to attach the antenna the magnetic mount works just fine and makes it easy to remove. Never understood why they didn't provide a plug for the power though.I like that hookup for the antenna. I mounted mine inside the dash, but I'd like to be able to take the antenna with the GPS to the truck. I have a second antenna, but with a different radio ID that'$ another .
