The bike is a 1997 with 179,500 on it right now. Bought it a couple years ago with 154k. The original owner kept meticulous records, so I know for a fact that the last one was done on time at 101k. That gives me another 10k before I really need to do it (this is my commuter and that will take me about 6 months).
This won't be the first timing belt I've done, as my first ST1100 came with an unchanged belt at 114k, and I changed it at about 120. I was shitting bricks the whole time as an inexperienced shade-tree just shy of his 21st birthday, but it went fine and I had no problems with that one for the next few thousand miles until swapping to this one (because heated grips).
This time my plan is to do the water pump as well while I'm in there, as the records indicate that it has not been done. My full list right now is:
-Change Timing Belt
-Change Water Pump
-Change Coolant (obviously)
-Check Valve Clearances (which will probably be fine from everything I've read)
Should I change the tensioners as well? Records indicate they have not been done. What else, if anything, needs doing?
Overall the bike runs like a top, and I'm incredibly proud to have such an old motor that still performs so reliably. I'm looking to take care of anything important, but anything non-essential I probably won't do because I need to be in and out fairly quickly so I can go back to using it as my commuter. Thanks all!
-Change Timing Belt
-Change Water Pump
