Double banjo bolt at master cylinder
Scotland
Evening!
I’m in the process of rebuilding my 1990 Pan and I’ve purchased a set of 2 line brake lines.
I have a double banjo bolt for the lines at the master cylinder, but it just doesn’t look ‘right’ to me.
Does anyone have a similar set up that can share a photo??
Millgrove, ON, Canada
2016 Versys 1000
6627
I would have turned them down too.... don't know what you have, but sometimes there was a tab cast onto the master cylinder to position the original lines.... many who went stainless simply cut that tab off with their Dremel..... if that is preventing you from rotating them down.
mello dude
Dayton Ohio
Assuming the hardware is correct, functionaly there's nothing wrong with it. That's one way to go with new SS lines, there 4 or 5 other ways with single banjo too.
GGely
Oshawa, Ontario, Canada
2001 ST1100 Non ABS
8997
I think it depends on what triggers your ADD... :)
I don’t have picture handy but mine currently look like yours, OP, from what I recall. On other bikes I’ve done, they’ve pointed a variety of directions.
Mine may change shortly since I’m moving to the CBR600 F3 master cylinder. I’ll post before and after pics when I’m done.
the cueball
Scotland
Thanks all, yeah it’s the ‘tab’ on the master that seems to be causing me the pain.
brakes all work fine, great feel and pressure.
I’ve just rebuilt the calipers and have new seals, pins, pads and lines…and have a vacuum bleeder, so even with new dry lines and a stupid archway it wasn’t an issue.
but as I say, doesn’t ‘look’ right to me!
I may try and put the lines under the tab rather than on top of it see if that works/looks better…
@Smudgemo - have you ground down the tab? I see your banjo is straighter than mine (no laughing at the back!! :p)
Bahama, North Carolina USA
2003 ST1300
the cueball
Scotland
Ah - ok. Goodluck and happy riding!!
Thanks.. maybe one day...
it's sitting looking a little sad at the moment waiting on tyres, exhaust, paint, and probably a load of others things too.. but one day! lol
lots of things to be done… now a waiting game for said tyres…
Smudgemo
Intermodal Man of Mystery
Berkeley, CA
'08 GS / '78 CB550
I don't recall cutting anything, but I got the bike with the two lines, so it's possible and it was gone and I never noticed anything. I don't have it anymore so I can't look. I also agree that the upward route you have will work fine but any air in the system will be a hard to remove.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
My ST-Rider group-buy double front brake lines installed below/under the tab on the master cylinder reservoir without a problem, as for many others. Looks good. FWIW
