On the way home, the other night from work i noticed that at a stop light my F1 light came on And stayed on i was wondering exactly what this is and how I can fix it. I am new to the form I need help. Any help appreciated, thank you in advance.
Thanks Chris will address this on the weekendHi Philly D.!
Welcome to the forum and I am sorry to learn you are having a problem with your STeed. As you may know, the FI light operates similar to the check engine light on a car. It can be triggered for numerous reasons. Unlike a regular check engine light, it can be used to reveal the triggering condition.
Under most conditions, the code condition that triggered the light will be stored in the PGM-FI unit. To determine the code, place your ST on its center stand, put the kickstand down, and with the transmission in Neutral start the engine. If the code is stored, the FI light will begin to blink. Next, count the blinks. One long blink equals a count of 10, but a short blink counts as a count of one. The blinking sequence will repeat as long as the engine is running and the sidestand is in the down position.
For example, a problem with the left knock sensor will give you a code of 25 [two long blinks followed by five short blinks]. If you don't have a Honda Service Manual, a list of the codes can be found here.
If you start the bike and there is no code (i.e., the FI light is not on) it means the codes has not been stored. To trigger the code and activate the FI light, let the bike warm up to normal operating temp. Once warmed up, increase the rpms until you get slightly over 4,000 rpm. Leave the revs at 4K rpms for 5-10 seconds until the FI light comes on. At that point, the light will begin its series of blinks.
You will not be able to begin addressing the problem until you know the fault code. Once you find that out, please post your results in this thread or send me a PM.
Your not doing your bike any favors by riding it with the code 26 flashing.Welcome to the forum! I recently had the FI light come on after owning my 2005 for 8 years. I'm receiving code 26 which is fairly common. I'll start diagnosing the issue when I do maintenance on the bike this winter. Fortunately, it still runs mostly normally (with the fuel economy a bit lower than before). It came on repeatedly on my trip to the Blue Ridge Gathering last month but hasn't come on at all doing local riding since then.
Well, fortunately the light hasn't flashed since I've returned from my trip and ridden only locally, so I'm not riding it with the light flashing. I'm really only riding it until I run the gas out of the upper tank enough to remove it if I need to before I start tearing into it.Your not doing your bike any favors by riding it with the code 26 flashing.
While you may think it runs mostly normal, and its just the fuel economy, your slowly killing your bike.
Your ECM is confused and does not know what to provide to things, making your bike run dangerously hot, and it may/will damage plastic parts, sensors, and wire harnesses.
Just saying
