perfect, better rating . Just be very carefull not to over tighten the fill plug. They break easilyHello all.
I plan on changing the final drive oil on my 2010 ST1300 and thought I would ask if anyone has heard of any issues using Mobil SAE 75W90 synthetic gear lube. I think it should be fine but it never hurts to ask.
Thanks.
Popcorn not needed. The question has been answered.
With a lead like that, I wanted to be prepared. All things being equal, I will probably use it myself.any issues using Mobil SAE 75W90 synthetic gear lube
+1 me tooI mark the oil fill cap location with a pencil witness mark before removing.
When tightening, I go back to the witness mark and a hair more.
Plug is made out of pot metal and breaks easily.
Curious to know if you mean that you use the original pencil mark as a permanent reference for this procedure?I mark the oil fill cap location with a pencil witness mark before removing.
I just stop when I feel the cap lightly seat after the o-ring is compressed. Tightening further will not compress the o-ring, it'll just lead to breakage, either immediately or when one tries to remove it later.I mark the oil fill cap location with a pencil witness mark before removing.
You are correctCurious to know if you mean that you use the original pencil mark as a permanent reference for this procedure?
Not sure if you own a 0"-1" micrometer, if you do measure a hair, you"ll find that that they are around .003".the second time that the final drive oil is changed, the starting point is now a hair more than where it was at the first oil change. At installation it will now be tightened an additional hair passed this new starting point. The third time will advance this by an additional hair tighter. Each subsequent time will be an additional hair tighter than the previous time. Eventually it will be tightened sufficiently to break the cap.
They're probably the same caps that were on the 750-4s as well as a bunch of other Hondas. I've never had a stuck cover but I remember looking at the underside and saw how thin the aluminum was. It was easy to image how the hex portion could be ripped right off the cap were it sufficiently stuck.I used a large pair of Channellocks to grip the outer diameter of the cap, not the hex-shaped dome. It was quick and easy.
