The main issue I had w/ my 1975 GW was the dual points setup. As Tournut posted, continuing problems with the timing and monthly maintenance for that was frustrating. The add on "electronic ignition" system (about $75) I added in 1977 was high priced, but made a huge difference on mine.I had three 1978 GL1000's. All were low mile garage sale finds that I rebuilt. Rebuilt everything with soft parts in it. Carbs were a bit fiddly at times but never a real problem. Timing on all the bikes required what seemed like monthly adjustment or performance suffered. Road manners were good but it was a bit cramped for two on road trips.
Never could get used to the 'rolling sofa' look of the later model Goldwings although friends who owned them had no issues with them.
Moved up to ST's.
As a side story: I had a '73 CB750, which also had dual points, but never put in an electronic replacement. I remember that I used the turn-signal beeper as the points-opening indicator instead of a bulb. Made it much easier to set them just right.The main issue I had w/ my 1975 GW was the dual points setup. As Tournut posted, continuing problems with the timing and monthly maintenance for that was frustrating. The add on "electronic ignition" system (about $75) I added in 1977 was high priced, but made a huge difference on mine.
I don't get that one...As a side story: I had a '73 CB750, I remember that I used the turn-signal beeper as the points-opening indicator instead of a bulb. Made it much easier to set them just right.
I'm talking about setting the timing statically, so the points open at the timing mark.I don't get that one...
I remember filing the 2 sets of points, adjusting the gap and I think, then I used a timing light for fine tuning...that was a long time ago.
