- Joined
- Feb 11, 2006
- Messages
- 9,665
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2024 Miles
- 010688
- STOC #
- 6651
The mileage is now 86,244. First, the front right side of the engine was very dirty with an oily residue I immediately and perhaps rashly attributed to the square weep hole in that area. Some of the oil was blown back where it collected some lesser amounts of grime at a few spots along the right side of the crankcase. I cleaned it all off before I read various posts on this so I do not know if it was from the square hole or the round weep oil of the water pump. I did not even remember there were two holes on the right front side that might weep or drip fluids - all I wanted to do was clean it up before pulling the valve cover on that side. It was definitely not the valve cover gasket, much too low on the engine for that and all around the cover was clean. I read up on the weep hole coolant or oil leaks after putting the buttoning everything back up. I guess I will ride it a few hundred miles then pull the cowl off the right side again and determine the actual weep point. I did not think it was coolant at all - too oily. No oil use yet between 5000 mile changes. It is not a drip or leak (a seep or a weep?) and it was not there 20,000 miles prior. I do my valve checks at about 20,000 mile intervals
The other was the foremost exhaust valve in the #2 cylinder came back loose .008". The .009 petal was no-go and .008 was very loose. I tried the .006 and .0025 petals stacked and it passed real draggy so I know the clearance was more than .0085" but less than .009 with .009 being tolerence in inch measurement units in the service manual. I see that the metric clearance is .25 mm with .03 mm tolerance converted to inches is .0087" so I am at or just beyond the limit of tolerance with this valve. I did not have a shim kit or desire to put the bike out of service until I could get the stuff together so I put it all back together with plans do this again in a few thousand miles. This valve of course is very easy to measure and was a tight .010 at 23,000 miles and .009 at both 45,000 and 65,000 miles. The bike as usual is running great and am not much worried about running the bike awhile like this but I can't ignore it either. I guess I'll have to learn how to do the shim under bucket adjustment soon.
